tiago-moura
Export/Import Default strings
Hi there,
I'm using a modern theme and portuguese (pt-BR) langauge as well, but the strings are not translated so I did it for all strings. As I have a couple of installers, I need to export these strings from one ai projetct to another one.
How can I proceed?
Thanks!
Re: Export/Import Default strings
This can be done using the Repository Manager feature.
Resources exported in the repository can be used in new projects very easy. For dialogs and prerequisites use the option "Add from Repository". Dictionaries are automatically loaded in the project if their corespondent language is selected.
tiago-moura
I just managed how to get it. I just found where the dictionaries are being created and then import in the other solutions.
You're welcome,
If you have other questions, please let me know.
