Alex99
Installer ignores install features conditions
Hello. I use Advanced Installer 11.7.1 build 61774 and I have a project which has a 24 features, some features have a lot of files. When I updated to Advanced installer v12.4(on 12.4.1 reproduces too) installing of some features began ignore it's installing condition. I allow User choose components to install by checking checkboxes, and feature has condition like
But some feature does not installs when condition is true. When I change condition to
feature installs successfully.
Installer is using "Enhanced User Interface".
Issue is not reproduces on simple project. I have project with similar behavior: https://www.dropbox.com/s/7g7bnq17pwtxf ... ir.7z?dl=0 There project which have several install features, features have a lot files with long names. If user choose to not install feature, feature installs anyway.
Re: Installer ignores install features conditions
Hello Alex,
Indeed, there were discovered several issues with our "Updates Features' Install States" custom action in the latest versions of Advanced Installer. We are aware of such kind of issues and a fix will be available in a future version of Advanced Installer. We'll notify you as soon as the fix will be out.
Until then, as a workaround you will have to use the old Advanced Installer version (e.g. 11.7.1).
Alex99
Thank you for reply. I will look forward to the new version.
The issue regarding the Features state is not updated accordingly with their install conditions on ConfigureDlg was fixed in version 12.6 of Advanced Installer released on December 8th, 2015.
