chandrabhushan
CAN I USE file server or shared location for updater installer download url
Hi Team
Thanks for continous support
CAN I USE file server or shared location for updater installer download url .
as i can see http, https are allowed but my installer size is big so i can't upload and download it .
Please let me Know how to do it
Re: CAN I USE file server or shared location for updater installer download url
Please note that the Download URL field from the Updates Configuration Projects allows you to add network location from where the update file should be downloaded from.
Examples:
  • Local network: file://\\computername\path\filename.ext
  • Local computer: file://c:\updates\file.exe
chandrabhushan
Hi Den
Try to implement the same But error came. Please see the screenshot .
Can you please make sure that the shared location is accessible? Can you please try to install the latest version of Advanced Installer and see if the behaviour still persist? Starting with the 12.4 version of Advanced Installer you should be prompted for password.
