karthick.k
Class Not Registered Error
We are getting a 'Class Not Registered' while launching the application.
Not sure what cause this error. The issue seems to be happening only on few machines.
MSI (c) (F8:C0) [11:43:28:842]: Doing action: AI_LaunchApp
Action 11:43:28: AI_LaunchApp.
Action start 11:43:28: AI_LaunchApp.
MSI (c) (F8:78) [11:43:28:853]: Invoking remote custom action. DLL: C:\Users\JReal\AppData\Local\Temp\MSI9B07.tmp, Entrypoint: LaunchApp
Action ended 11:45:06: AI_LaunchApp. Return value 1.
Action ended 11:45:06: ExitDialog. Return value 1.
Please assist us on resolving this. Attached is the screen shot.
Re: Class Not Registered Error
I'm not sure why you encountered the this behavior.
karthick.k
Hi Dan,
Here is the link to download the project file and the log.
https://drive.google.com/file/d/0B0RTDi ... sp=sharing
Did you get the error when generating the installation log file? As I can see in the log, there is no error encountered.
karthick.k
Hi Dan,
Yes, we are not getting any errors while installing, we are getting the error only when we click on the 'Launch Application' check and click ok.
We are launching the application through an URL link.
We can still access the same link directly, which is failing only when it is launched from the installer.
Thank you!
Can you please try to use the predefined Open URL custom action to open the URL page?
For this, you need to add the custom action as a custom action without sequence. For details, please take a look on the How to execute a custom action when a button is pushed? article.
Let us know if the behaviour still persist.
