tomas.maruska
Hyperlink in ExitDialog caused problem on Windows Vista
Hi guys!
I encountered problem with uninstalling on Windows Vista.
I was able to reproduce this problem on small project (find attached). The thing is, that I have hyperlink on exit dialog. Because hyperlink is supported on Windows Installer > 5, I have Enhanced UI turned on.
Installation is OK.
Problem is on Windows Vista, when I want to uninstall program from 'add or remove programs' dialog. At the end of uninstallation process I get "Failed to create the control Hyperlink_1 on the dialog ExitDialog.". Program is uninstalled successfully.
I use AdvancedInstaller v1.6.3.
Is there any way to not to get this error dialog?
Best Regards,
Tomas Maruska
support@gamanet.com
Your Application.zip
(953.95 KiB) Downloaded 331 times
Your Application.aip
(17.2 KiB) Downloaded 443 times
Re: Hyperlink in ExitDialog caused problem on Windows Vista
Hi Tomas,
In order to overcome this, can you please try to set the Enhanced User Interface to Always (install, uninstall and maintenance) and see if the behaviour still persist?
tomas.maruska
Hi Dan,
Thanks for instant answer!
Turning Enhanced UI to 'Always' helped. But, it changed my settings in Product Details -> Add or Remove Programs (Control Panel). When I changed it back to my original settings (see on screenshot), it changed Enhanced UI to 'Only on Install'.
Why?
Tomas Maruska
support@gamanet.com
You're welcome Tomas,
Indeed, the related options are not compatible with the Always (install, uninstall and maintenance) option of the Enhanced User Interface; you are also get a notification about this:
EUI Notifications.png (20.66 KiB) Viewed 6208 times
tomas.maruska
Hi Dan,
Thank you for your help, it works as I want.
Best Regards,
Tomas Maruska
support@gamanet.com
You're always welcome Tomas,
