aeplengg
Application Folder
We have created the adi setups for a VS2008 application
1> abcV1.exe for third party integration. Which takes the APPDIR as command line argument from third party setup.
2> abcV2.exe for stand alone installation.
we have added two custom actions to set the directory path, attached screen shots
1>SetDirectoryPathNOTTARGETDIR
2>SetDirectoryPathTARGETDIR
Suppose we have installed this thrid party setup (which includes abcV1.exe) followed by the stand alone setup (abcV2.exe),
the stand alone setup takes the application folder supplied by the third party application.
how does this happens?
Swati
Re: Application Folder
aeplengg
We are sending you the "My Tool.aip", with two set-ups named as 'My Tool Setup V1.0.0.exe' and 'My Tool Setup V2.0.0.exe'
Rename extension of 'My Tool Setup V1.0.0.aip' and 'My Tool Setup V2.0.0.aip' as .zip. Extract zip files.
1> My Tool Setup V1.0.0.exe Run this setup with command line argument (TARGETDIR="%PROGRAMFILES%\COMPANY-1\MY TOOL\"
2> My Tool Setup V2.0.0.exe Run this set-up directly
Now can you please explain us how the second set-up takes the application folder path as supplied by first set-up
regards
Swati
(1009.96 KiB) Downloaded 259 times
(1010.08 KiB) Downloaded 266 times
My Tool.aip
AIP file
(18.18 KiB) Downloaded 354 times
