bstienst
VSIX
I have an existing Advanced Installer that installs my entire product. I want to add a feature that installs a Visual Studio 2015 Plugin. I have the plugin functional and I have a VSIX file and I need Advanced Installer to install the VSIX file as part of installing the feature.
The documentation says to create a VSIX file from Advanced Installer, but since I already have a VSIX I just want to embed this VSIX file in my installer and run it.
I've added the file, but I'm not sure how to make Advanced Installer install the VSIX file. I was hoping it would just do that based on the file type, but that did not happen.
Any ideas?
Re: VSIX
For this, you can follow the steps described in the Create VSIX Installers tutorial to create a project for a Visual Studio Extension installer (VSIX).
Then, you can add the resulted VSIX package as a prerequisite to your existing installation. For details, please take a look on the Add prerequisite article.
Let us know if you have other questions.
MarcelloS
Re: VSIX
Hi Dan,
Whether I add it as a prerequisite, what about the uninstalling process, does it uninstall the VSIX package as well?
Re: VSIX
Hello Marcello,
If the package has an uninstall command line, you can pass that through the "Uninstall using this command line" field from the "Prerequisites" page.
