mcseforsale
Collecting return code from Custom Action Executable?
I'd like to be able to collect the return code from an executable launched from a custom action into a property. Is this possible?
Andy
Re: Collecting return code from Custom Action Executable?
Hi Andy,
Please note that you cannot set a property from an .EXE custom action. Also, custom actions that are executable files must return a value of 0 for success. The installer interprets any other return value as failure.
You can try to create your .EXE custom action as a .DLL custom action. For details, please take a look on the How to integrate and debug custom actions? article.
mcseforsale
Thanks! Our particular executable will identify if any version of Firefox is installed on the client, and set the return to 0 for any version and another number for none installed. Can I action off this return of 0? I guess I don't necessarily need to get it as a property, I just need to be able to action off it's return success.
Thanks!
AJ
Hi Aj,
Yes, this should work. However, the error that the user will get is not very friendly or meaningful (see below):
Return code.png (7.57 KiB) Viewed 3826 times
I strongly recommend you the .DLL approach as explain in the How to integrate and debug custom actions? article. For example, you can create your custom action as a custom action written in C# or a custom action written in C++
If you need any help, please let me know.
