NigelShaw
64 bit problems
Hi
i am using the wizard to set up a 32/64 mix for my installation. When i build and then install, i am getting this message and the install stops-
when i start from scratch and leave it as 32 bit, it works fine.... any ideas?
cheers
nacho
Re: 64 bit problems
Hello Nacho,
