chandrabhushan
Unable to uninstall post applying Patch
I have created a patch by help of http://www.advancedinstaller.com/forums ... =5&t=31012
But Post installing the patch i am unable to Uninstall both (either Base v1.0.0 or Patch V1.0.1) .
Also
There are 2 entries in the uninstall or change program(control Pannal) (see attachment ) . And i am unable to uninstall any of them .
Also
I want to run repair on both the entries .
Please let me know what and how to solve the issue and implement these things .
Re: Unable to uninstall post applying Patch
Please keep in mind that our "Enhanced User Interface" feature is not compatible with the patch creation process. When using the "Surface" theme (from "Themes" page) the EUI feature will be set to "Always (install, uninstall and maintenance)" and as a requirement the "Override Windows Installer programs list entry" option from "Product Details" page will be enabled. But, unfortunately when the "Override Windows Installer programs list entry" option is enabled you won't be able to build patches for your product.
Therefore, you should either use a theme which doesn't use the EUI feature "Always (install, uninstall and maintenance)" or build your new product version as a major upgrade instead of a patch.
For testing purposes we always recommend to be used virtual machines with clean states so that when something goes wrong you can easily revert to a clean state of the virtual machine. Also, to remove a broken installation you can try to use the "Fix it" Microsoft tool.
