ANikolova
Security Alert messages
Hello guys,
One other problem we are having with our client auto update. Is showing lots of unwanted messages.
The server is hosted on the IIS and is using SSL. For this purpose we have a self-signed certificate installed on the server.
When we start the client, which starts the updater.exe three messages show, as attached bellow. When finished download of the new client update exe, then these messages show up again. Strangely enough, the second showing of these messages happens every now and then. What I mean is, we have tested the update couple of times, on different client machines and they don't show up every time.
Do you have any suggestion on how to prevent them showing the second time?
Thank is advance.
Third Message
Third Message
Second Message
Second Message
First Message
First Message
Re: Security Alert messages
I'm not sure why this happen randomly, but those messages are spawned by the Windows operating system itself. Basically all the updater does is to download the updates configuration file locally and, then download the updates setup package if required. Therefore, the related Windows messages won't be triggered when your product is up to date and no updates setup should be further downloaded.
ANikolova
I understand that, but for our users will be quite confusing to see three messages, and even six some times. This can lead to increase custom support from our side, and moreover, some users might not be able to update at all because of the problem described in http://www.advancedinstaller.com/forums ... 032#p83972
