Solartron
using the AI wizard to create an Excel Add-In installer
Dear support,
I have created an installer for a VSTO Excel Add-In using the AI wizard. It works okay but when viewing the COM add-ins from Excel, my add-in is listed as "Your Excel add-in" instead of the Product Name. After some research I have discovered that the "FriendlyName" property needs to be set to the required text. The AI wizard does not provide the option for this and I don't think it's obvious where this setting is located or even what its purpose is. Ideally, I think AI should default the "FriendlyName" to the [ProductName] property and allow for it to be modified from one of the wizard pages.
Thank you.
Re: using the AI wizard to create an Excel Add-In installer
The "FriendlyName" value can be set from the "Add-in Configuration" Wizard dialog, as displayed in the attached image.
Also, you can set that name by modifying the value of the following registry entry from the "Registry" page of your project:
Current user/Local machine\Software\Microsoft\Office\Excel\Addins\[Manufacturer].[ProductName]\FriendlyName
Office Add-in.png (33.8 KiB) Viewed 2723 times
Solartron
Thank you! I missed that one. I found the setting on the registry page but still think that it's not totally clear when first creating an Office add-in installer what the Friendly name setting is. It's not until I viewed my add-in in Excel that I saw the name "Your Excel add-in" and then found the setting on the registry page. Maybe this is down to my lack of experience with installers.
I could not find any reference in the help for this setting, perhaps something could be added in the help to explain what the setting is for? Maybe it would also be good if the Friendly name did default to the [ProductName]?
Thank you.
We'll consider your suggestions and we will implement them in a future version of Advanced Installer. Thank you for your feedback.
