adubois
missing french translation
Problem: French translation is missing on some screens of the setup.
Environment: All windows version using Single EXE setup with advanced installer 12.4.2
How to reproduce:
1- Open setup.exe when there is already a newer version
2- You will see "Preparing", "Checking for a newer version...", "There is a newer version of..."
3- Click "Oui"
4- You will see "Preparing...", "Downloading", with "Cancel" button
5- Click Cancel while downloading, you will see "Failed to download..."
1- Open setup.exe without newer version
2- You will see "Preparing to install..." with "Cancel" button
1- Open uninstall.exe
2- You will see "Preparing to remove..." with "Cancel" button
Re: missing french translation
Indeed, this seems to be an Advanced Installer issue. A fix will be available in a future version of Advanced Installer, thank you for bringing it to our attention.
We will notify you on this thread when the fix will be available.
adubois
Some others screens are not translated in French
Here are the screen shots:
** update : I've just remove the attachments since there are translated in french with Advanced Installer 12.4.2. You can ignore this reply.
This was fixed in version 14.2 of Advanced Installer released on July 26th, 2017.
