Trax
Project Error
I have an .aitemplate file that I use to build out .aip files. However, this time when I used the template my Application Folder and all File Operation files are showing strange icons.
What do these icons mean?
Re: Project Error
I'm not sure where the related icons come from. I suspect this is related with the machine where you load your project.
So, can you please open your project on another machine and see if the behaviour still persists? FYI: according to our EULA, you can install and use Advanced Installer on up to five computers (including operating systems and Virtual Machine Environments) that are connected to each other in a network (there has to be a TCP/IP connection between these computers).
