MartinRoling
Error when installing Windows Feature (Framework 3.5 and 4.6)
I use the Advanced Installer 12.4.2.
I want to activate the Windows Feature '.Net Framework 3.5 (Includes .NET 2.0 and 3.0)' and '.NET Framework 4.6 Advanced Services' on a Windows 10 computer.
During the Installation I get the following error
'There was an error during then Windows feature configuration process. Your original configuration will be restored.'
When I activate the two feature manually, It works as aspected.
I've attached my aip file.
Is there anything wrong in my installation script?
Best regards
Martin
NetFrameworkActivator.aip
(24.16 KiB) Downloaded 406 times
MartinRoling
Re: Error when installing Windows Feature (Framework 3.5 and 4.6)
Here is the verbose log
NetFrameworkActivator.log
(206.88 KiB) Downloaded 325 times
I'm not sure why you encounter this problem. Can you extract the attached debug DLL file in the "C:\Program Files (x86)\Caphyon\Advanced Installer 12.4.2\custact\x86\" folder, then rebuild and retest your package? It will create a "C:\AI_WinFeats.log" file that you can send to us, so we can better investigate the problem.
MartinRoling
Hello Eusebiu,
there is no DLL attached to your post?
Martin
Sorry Martin,
I forgot it. I attached it now.
WinOptionalFeatures 12.4.zip
(733.53 KiB) Downloaded 277 times
MartinRoling
Hello Eusebiu,
here is the log file.
Martin
AI_WinFeats.log
(412.54 KiB) Downloaded 343 times
Hi Martin,
We looked over the log file that you send and we found that the problem you encounter is a Windows 10 problem which we were already aware of.
We found a workaround for it and the improvement is included in the next version of Advanced Installer which should be released soon. We will update this thread when it will be available.
MartinRoling
Hi Eusebiu,
Thank you.
Martin
You're welcome Martin.
Just let us know anytime you encounter a problem.
This improvement has been added in version 12.5 of Advanced Installer released on October 21st, 2015.
