llc-elliot
DialogBitmap not visible
Hi all,
I am using Advanced Installer Pro. I am trying to customise the dialog background of an installer based on the Spring theme. In User Interface > Themes > Preview, the DialogBitmap (JPEG) displays (see first image), but when I run the installer, it either doesn't display, or is not being scaled to the size of the dialog window (see second image). At the moment, I have "Adaptive stretching" selected in User Interface > Themes > Settings > Image Scaling, although I have tried all of the other options too to no avail. Thanks in advance for your advice!
Re: DialogBitmap not visible
I'm not sure why you encounter this problem. Can you please send us the .AIP (project file) and a verbose log of the installation to support at advancedinstaller dot com, so we can investigate them? The image that you use as a background would also help us to investigate the issue.
Please note that the size in pixels for the Dialog image of the Spring theme is 600 x 480. For details, please check the Themes article.
As mentioned above, the problem seem to be caused by the size of the background picture that you use. The image is to large and it gets outside the boundaries of the theme's dialogs. Can you use the dimensions I mentioned above and see if the problem persists?
llc-elliot
Eusebiu wrote:As mentioned above, the problem seem to be caused by the size of the background picture that you use.
Wow, it really was as simple as that! Thanks for your help.
You're welcome. Glad to help.
Just let us know anytime you encounter a problem.
