chandrabhushan
AI_Recyclebin Folder on all drives and Still remains Post Un-installation
Post uninstallation we can see the large files under AI_Recyclebin Folder . its eating up all server memory .
Please let us know what is the issue . I also checked other threads in the forum .
Please note that i am Picking files as .7zip and extracting it with the help of batch files . . after uninstallation I am unable to remove all files so
using force delete of the files Post Uninstallation .
Please Help ASAP .
Screen-Shot Attached .
Re: AI_Recyclebin Folder on all drives and Still remains Post Un-installation
I'm not sure if this is the case, but this may happen if you are using an older Advanced Installer version than AI 12.3. There were some issues with the "AI_Recyclebin" folder in the past. Can you please rebuild your setup project with our latest Advanced Installer version (12.5) and let us know if the issue still replicates? If your license maintenance plan doesn't cover our latest application version, for testing purposes only, please download and run our latest version of AI in trial mode.
If you are already using our latest application version to build your setup project, then please send us the .aip (project file) to support at advancedinstaller dot com so we can investigate its settings and test on our side.
