karthick.k
"Error Opening file" error
We are getting the below attached error while running the installer in a shared drive. We found our previous version of installer are worked fine in the same shard drive before.
Please assist us on resolving this.
MSIB583.zip
(484.58 KiB) Downloaded 224 times
Re: "Error Opening file" error
I apologize for my delayed reply but we were a bit busy lately.
This may happen if you are using an Advanced Installer version below AI 12.3. In older Advanced Installer versions our "XML Update" feature didn't have support to write on network shared locations. So, can you please make sure you are building your setup project using AI 12.3 or a newer version? If so, can you please send us the .aip (project file) too to support at advancedinstaller dot com so we can investigate its settings?
