chandrabhushan
PopUp window comes and stays for 10 sec during the installation
Whenever I am installing the installer, One PopUp window comes and stays for 10 sec during the installation . This is very annoying . Please note that my all custim actions are handled only by hide Programs window available in the AI..
On top of the window it seems reading some Temp file .
Please Let me know how to resolve this issue .
ScreenShots attached : -
Re: PopUp window comes and stays for 10 sec during the installation
I'm not sure why you encountered the this behavior.
chandrabhushan
Hi Den,
Thanks for the reply,
I am sry I can't send you the .aip file because of company confidentiality, Also you can't ask .aip files from the users for each and every issue .
As far as my observation, it may be happening once i try to launch an exe (fart.exe, Which finds and replaces a string across my installed folders .
Please help .
I have tested your scenario but I cannot replicate it.
in order to further investigate this, can you please try to isolate the behavior in a buildable sample (.aip + its referenced files) which we can build and test on our side. This will help us greatly to provide a solution in the shortest possible time.
