chandrabhushan
Choose features Options
I have implemented the choose features in my set-up using a dialogue and selection tree and I am getting 4 options for each feature . I just want 2 options
1. will be installed in local hard drive
2.entire feature will be unavailable .
Please help me with this .
Screenshots attached [desired features are marked as blue Mark ).
Choose features.PNG (12.65 KiB) Viewed 2263 times
Re: Choose features Options
You can disable the Disable advertise option from the feature properties in order to remove the Feature will be installed when required option from the context menu of a feature in the Selection Tree control. However, the rest of the options will persist in the context menu of the feature.
However, if you want to have only these two option (install the feature or not), you can use the Quick Selection Tree control. The Quick Selection Tree is an improvement to the simple Selection Tree. The regular Selection Tree control offers a drop-down menu for each feature where you select whether that feature will or will not be installed. The Quick Selection Tree control replaces the drop-down menu with checkboxes.
If you have other questions, please let me know.
