Manshet
Checked RadioButton
Good day.
How to make so that you can make a choice function (component) by using RadioButton?
The screenshot I will add to the theme.
Thanks in advance.
Re: Checked RadioButton
Please note that the upgrade process performs the following actions:
  • -Detect and completely remove older products.
    -Install the new product.
As I can see, you want to either install either to update the installed application. I'm afraid this is not possible.
Please note that you can add the predefined UpgradeDlg dialog and ask the user if he wants to uninstall/remove the old version or to perform a side by side installation so that the old installed version will not be removed.
If you add the UpgradeDlg, then you should conditionally display it, so it only be displayed on a machine where a previous version is installed. For this, you can follow the steps from the How to conditionally show the "UpgradeDlg" dialog? article.
By the way, do you want to allow the installation of multiple instances of your product on the same computer? If YES, then you go in the Multiple Instances view to allow multiple instances of your product on the target computer.
Let us know if that helped, otherwise give us more details about your installation scenario.
