chandrabhushan
using find and replace in "text file update" utility
hi,
I am trying to update following texts with properties using "text file update" utility provided in AI in a single file .
SERVERNAME -->[SERVERNAME]
PORT --> [PORT]
DBNAME --> [DBNAME]
USRNAME-->[USRNAME]
PASSWD-->[PASSWD]
I tried to give all the search strings separated in" ," and replace strings in "," but its not working . Please advice .
Re: using find and replace in "text file update" utility
Can you please send us the .AIP (project file) and a verbose log of the installation to support at advancedinstaller dot com so we can have a better view of your installation project settings?
chandrabhushan
Hi Den,
Before asking for .aip can you please tell me what is the correct way to do it .
chandrabhushan
I want to use find and replace utility for a file , i am searching the strings and replacing with the properties from SQL dialogue. Please let me know what i am missing . any specific operator i need to give in find or what ?
Screenshot attached .
I'm sorry, but I'm afraid I cannot fully understand what you are trying to achieve. Can you please give us a more practical example of what you are trying to achieve? Please give us a 3 steps example like this:
1. the original file content
2. the file content which you want to search for
3. the updated file content after the file is updated with the new values
so we can have a clear view of what you are trying to search for and how you want your file to look like after update?
chandrabhushan
Hi Denial,
I have one standalone.xml file in my installation .
In this file i have to get data from user (from SQL Dialogue ) and then find different text/Pattern and replace it with the values i got from the textboxes
i.e
PORT --> [PORT]
DBNAME --> [DBNAME]
USRNAME-->[USRNAME]
PASSWD-->[PASSWD]
Here SERVERNAME,PORT,USRNAME are there in my xml file as it is . i have to replace it with my values . I am trying it through text file update but unable to achive it . Please see the screenshots in the thread .
Please help me ASAP .
chandrabhushan
please see the input file and output file
with the data captured through SQL Dialogue
PORT --> [PORT]
DBNAME --> [DBNAME]
USRNAME-->[USRNAME]
PASSWD-->[PASSWD]
See the screenshots.
Please note that to achieve what you want you should use regular expressions. You should add multiple search and replace operations like this:
  • Find: <connection-url>jdbc:sqlserver//*.*</connection-url>
    Use regular expressions: checked
    Replace: <connection-url>jdbc:sqlserver//[SERVERNAME]:[PORT];databasename:[DBNAME]</connection-url>
    Find: <user-name>*.*</user-name>
    Replace: <user-name>[USRNAME]</user-name>
    etc.
If you have any further questions let us know.
chandrabhushan
Hi Denial,
Thanks for the help.It is now working As expected .
**Please can you update the manual so that we can use these features easily .
Maybe we'll add more info about the usage of regexs with our text file update feature in a future version of Advanced Installer. Thank you for your suggestion.
chandrabhushan
Thanks ,
One quick question,
Is this search and replace works is sequence for example " first Replace --> then Replace_1 then --> Replace 2 ---> in the same test.xml file .
Yes, the find and replace operations are applied subsequently, one after the other.
