tiago-moura
Run command on uninstall process
Hi there,
I need to run a command when the software is uninstalled. This command should run an executable file located into installation folder to force a process which is running.
Could you advise how can I achieve it? Maybe a custom action?
Thanks in advanced,
Tiago
Re: Run command on uninstall process
Hello Tiago,
To achieve what you need you can try to use a "Terminate process" predefined custom action. The action should be added on uninstall after "Install Execution Stage -> Searches" action group.
Let us know if this helped.
tiago-moura
Hi Daniel,
Thanks for your prompt support.
Do you mean something like the image below?
Tiago
Hello Tiago,
Yes, something like that.
