hhelbig
32bit features wont be installed
I have 2 mixed platform (32/64-bit) projects with following problem since changing from v12.2 to 12.5 of AI:
All merge modules connected to 32-bit enabled features ('Installed' and 'Disabled if: VersionNT64') won't be installed at 32-bit systems any more.
If I create these setups with the older version 12.2 all is working fine!
See following my used configuration:
32bit feature
32bit feature
32bit feature.png (32.79 KiB) Viewed 3932 times
64bit feature
64bit feature
64bit feature.png (31.39 KiB) Viewed 3932 times
Parent feature of 32- and 64bit-feature
Parent feature.png (31.73 KiB) Viewed 3932 times
hhelbig
Re: 32bit features wont be installed
See attached sample project:
Setup.aip
Sample Project
(57.99 KiB) Downloaded 605 times
I've tested your attached sample project with a 32-bit MSM, but I cannot replicate the behavior. The 32-bit MSM resources are installed as expected. Can you also please send us a download link for your EXE setup, the AIPs of your main project, 32-bit MSM and 64-bit MSM and a verbose log of the installation to support at advancedinstaller dot com so we can investigate their settings?
