hhelbig
Problem after installation of prerequisites
After completing installation of prerequisites welcome screen of main installation procedure appeares.
While 'Computing space requirements' setup procedure crashes at some systems:
Setup crash after prerequisites .png (109.73 KiB) Viewed 5656 times
[SEH_AV_DEP_BADPTR] ACCESS_VIOLATION (0xc0000005) at address [0x0fffff7a]
Advanced Installer Enhanced UI 12.2 build 64035
*** Stack Trace (x86) ***
[0x0fffff7a]  -----
[0x74092c57]  MsiSetOfflineContextW()
[0x73f59c43]  MsiGetProductCodeW()
[0x73f5a086]  MsiGetProductCodeW()
[0x73f5a652]  MsiGetProductCodeW()
[0x73f812c2]  MsiGetProductCodeW()
[0x740b4a93]  MsiSetOfflineContextW()
[0x740052f7]  MsiSetOfflineContextW()
[0x74007ae2]  MsiSetOfflineContextW()
[0x73fb4e0f]  MsiDoActionW()
[0x014630c5]  -----
[0x01463058]  -----
[0x01460f93]  -----
[0x01462b4b]  -----
[0x01401f92]  -----
[0x014021ef]  -----
[0x0140215f]  -----
[0x0140297f]  -----
[0x01413bac]  -----
[0x77c49882]  RtlInitializeExceptionChain()
[0x77c49855]  RtlInitializeExceptionChain()
[0x013b0000]  MODULE_BASE_ADDRESS
In this case there is no way to end setup process at a normal way. We have to kill this.
After restarting the machine setup process could be run completely.
Re: Problem after installation of prerequisites
Unfortunately, we are not sure when this behavior reproduces. So far, it seems this happens only when our Enhanced User Interface feature is enabled, but it replicates very erratically and we could not isolate the behavior on our test machine. As a workaround you can try to disable the Enhanced User Interface in your project and see if the behavior still persist.
Also, can you please tell us if the behaviour still persist when using the latest version of Advanced Installer?
hhelbig
Dan wrote: Also, can you please tell us if the behaviour still persist when using the latest version of Advanced Installer?
Yes.
It seems to be a problem with one of the fresh installed prerequisites:
Because installation process runs properly after killing setup process and a reboot afterwards.
