mguenth83
Bug in Prerequisites ?
iam working on an Projekt to install 7-Zip as Prequirement in an MSI/EXE File. So my idea was to compfortly install/repair/deinstall this in prerquirement Section but this didnt work correctly.
To get more Information See Screenshot.
Based on This Requirement the follow Scerarios work or didnt work.
Install and Uninstall over the Advanced Installer works great.
Install and Uninstall over the direct MSI works great.
Install over MSI oder AI Console works great but Uninstall over Add Remove Programs doesnt work, it Comes up the uninstall Dialog.
Dos someone has the same Problems ?
Re: Bug in Prerequisites ?
I've tested and replicated the behavior. This seems to be an Advanced Installer issue. A fix will be available in a future version of Advanced Installer, thank you for bringing this to our attention. We'll notify you as soon as the fix will be out.
Until then I'm afraid there is no workaround. We'll update this thread if we manage to find a workaround.
This was fixed in version 12.8 of Advanced Installer released on March 23rd, 2016.
