prerak6962
No Admin Privileges demanded
I am building a simple application which I want to install with Admin priviliges.
I have selected the "Run as administrator" option in Install parameters tab. But when I run the it from advanced installer, it doesn't ask for any permission.
In the file browser, I can see the small "Admin sheild" icon, but if I double click it, it doesn't ask for the permission.
If I copy the exe to any other machine, the sheild icon is also gone and the same issue remains.
Advanced Installer Version: 12.5.1
I am attaching the screenshot of my configuration.
Please let me know, if I am missing something.
Re: No Admin Privileges demanded
Can you replicate the behavior in a buildable sample (aip + its referenced files) and send them to support at advancedinstaller dot com so we can test and investigate this on our side?
Also, please make sure you didn't already started the AI application elevated or that the UAC is not disabled on your computer.
prerak6962
Hi Daniel,
Thank you for the reply.
The UAC was disabled on my system so, that's why it was not showing the dialog.
Thank you the help.
Have a nice day ahead,
Prerak
You're always welcome Prerak.
Have a nice day you too,
