Ivan The Coder
Condition Column in Files and Folders
It would be great if there will be possibility to add Condition column in Files and Folders view. That column might show expression from file's Properties->Condition field.
I know that it's specific to only temporary files, but having a bunch of them (more than 10, where 3 or 4 used during uninstall, other during install) it's hard to quickly view their Condition fields (one should manually click Properties on each file).
Ivan The Coder
Re: Condition Column in Files and Folders
Hi Ivan,
We'll consider your suggestion for adding this feature, but for the moment there are not immediate plans. We'll consider this in a future version. Thank you for your suggestion.
Return to “Feature Requests”
