sagaru
App Shortcut launches a new instance of app each time
I added a application shortcut to Application shortcut folder. Followed your instructions from http://www.advancedinstaller.com/user-g ... ialog.html
Each time I click on the shortcut it launches a new app instance, I want to have only one app instance at a time.
Could you please let me know how to achieve this?
Re: App Shortcut launches a new instance of app each time
That is controlled from your application, not from the installer.
You need to talk with your developer(s), if you are not one of them, and see how you can limit it to one instance. This depends on
the framework used to build the application, etc...
