mhubel
keyless value in .ini file
Is it possible to have the installer generate an entry in a .ini file with no key, only a value? We want the resulting .ini file to effectively look like:
[Directories]
c:\nm\archive
where c:\nm\ would be replaced in the properties with [APPDIR]
Re: keyless value in .ini file
When adding an entry in the Edit INI File Dialog, you are forced to add a key (if the key field is empty, the Ok button is disabled), see below:
Add ini entry.png (45.27 KiB) Viewed 2412 times
You can add a blanc space in the Key field from the Edit INI File Dialog and you will be able to add an entry in the .ini without a key.
