fmh1959
JSON handling is needed
We have a very strong need for handling json files (equivialent to import of xml,ini files).
The new VS 2015 VNEXT is JSON all the way!
Regards
Re: JSON handling is needed
We'll consider your suggestion for adding this feature. Thank you for your suggestion.
Antarctica
Is there an ETA on this feature?
Unfortunately we cannot give you any ETA for now. I've noted down your request too and hopefully this feature will be available soon.
We will updates this thread as soon as the feature is out.
This improvement has been added in Advanced Installer 17.7, released on November 25th, 2020.
Return to “Feature Requests”
