korr
DWORD Registry Search return without #
I ran into this problem recently and a quick search shows at least 5+ issues with DWORD registry searching returning # prefixed to the number that is retrieved. The current suggestion for getting past this is to create a custom action to remove the # from the property.
Quick search results :
http://www.advancedinstaller.com/forums ... =2&t=31286
http://www.advancedinstaller.com/forums ... hp?t=29827
http://www.advancedinstaller.com/forums ... =2&t=30863
http://www.advancedinstaller.com/forums ... =2&t=30034
http://www.advancedinstaller.com/forums ... =2&t=28916
Re: DWORD Registry Search return without #
Indeed, this is the Windows Installer normal behavior when a "REG_DWORD" value is searched. As mentioned in the other threads, in order to get rid of that character, you can create a simple custom action that removes it from the search property.
Return to “Feature Requests”
