I am new here ( also sorry for my english)
I using searcher but not find answer how to do it, so I create new topic.
My problem is that I need to create very small installer for all previous user of my software which have bed install software( wrong registry) to create proper new one that Update system start work.
So I would like create installer which after installation ASK user to CHOOSE path for file "yyy.exe". So it will be not installed if user don't select "yyy.exe".
After that user select this path - installer create a registry value with Path what I want HKLM\Software\[Manufacturer]\[ProductName]
and install to this path updater.exe and proper shoutcut to desktop.
The most problem think for me is HOW TO CREATE this mandatory ASK for select file yyy.exe
- I can not use registry search ( because in most 95% this will be wrong path)
- I can not use file search because half of user have this time file few times.
Only why for me is option that they show me the path where file is saved. Then I will be have 100% that updater works well.
Thanks for all answers ( step by step )
Adam
