DavidPayne
Sim City 3000 Is Trying To Connect??
Strange question. I downloaded and installed the trial version of Advanced Installer. The first time I ran it, and now when I choose 'Check for updates' from the help menu, I get a warning from Norton saying "Electronic Arts SimCity 3000 is attempting to access the Internet".
The details tell me that the program 'updater.exe' with the path 'C:\Program Files\Caphyon\Advanced Installer 5.2.1' is trying to connect to 216.92.133.236 : http (80), by TCP.
I assume this is a bizarre mistake in some kind of meta data, but just thought you should be aware. For the time-being I'm blocking it, just in case.
Cheers,
Dave Payne.
Ionut
Hi Dave,
When AI is launched or the "Check for Updates" menu item is used, the Updater is executed and it connects to our web server in order to determine if any updates are available. This behaviour is normal and there is no need to block it - the Updater does a HTTP GET in order to retrieve the "updates.ini" file.
Probably the NAV signature database on your system is out-of-date. If this is not the case, then it just happens that the NAV signature for "Sim City 3000" matches a series of bytes from the Updater EXE.
Ionut
Denis Toma
Advanced Installer Team
DavidPayne
I appreciate this explanation, and, of course, realise that it's not necessary to block it. However, as maro158 mentioned here: http://www.advancedinstaller.com/forums ... php?t=1666, if we were to buy Advanced Installer, we wouldn't want our customers to get the same message.
I guess my question is: is updater.exe the same application that would be used by for updating our software; if we buy Advanced Installer, will we get technical support requests from our customers, asking why we're trying to install Sim City on their machines? We sell to mostly non-techy, home users, who tend to feel panicked by messages from anti-virus software at the best of times.
I do understand that this is a difficult question, having had to try and solve a similar problem with my own software in the past, but if there's any further research you guys can do, I would very much appreciate it - I really like the software, it does everything I need and for the right price, but I would have trouble explaining this issue to my (very non-technical!) boss, let alone to customers.
Many thanks.
Ionut
Hi Dave,
We have tested this using the latest version of Norton Internet Security and we could not reproduce the problem. Please give me more details about the NIS version you are using.
The same Updater EXE (in which the icon and language resources are injected, if necessary) is included in the built package when this feature is selected in the Updater page.
Ionut
Denis Toma
DavidPayne
Thanks for the quick response. I'm using a version of Norton Internet Security that came bundled with a Sony Vaio (VGN-N38E). It's a brand new machine, and I'm running Vista (it's possible that Norton was bundled with Vista, rather than the machine... not sure - I switched it on and there it was!).
In the About box of Norton I see version 10.1.0.26. Sony EU(90). I allow it to do it's own live updates, which say that they're up-to-date, so I'd imagine that things should be OK there?
Sorry - I know I'm not being very helpful, but don't really have much more that I can add!
Thanks again,
Dave.
