IceRobot25
Unicode characters support in MSI Summary Information
I'm trying to build a MSI with a product name containing Unicode characters. When I opened the properties of the MSI file generated by Advanced Installed, I noticed that the subject characters aren't encoded correctly. You can see the result in the following image.
Does the MSI summary information page supports Unicode characters?
I enabled the UTF-8 option in the Builds->Database Encoding option.
You will find the project .aip file attached to this post.
simpleMsi.aip
(11.13 KiB) Downloaded 430 times
Re: Unicode characters support in MSI Summary Information
Can you please attach the .AIP (project file) and the printscreen? It seems there was a problem when tried to attach them previously.
IceRobot25
I've attached the image and aip files in the original post.
Marc-Andre
mihai.petcu
Hi Marc-André,
This only works if you create the project using that specific language. You can set the project language when creating the project from the Start Page > New > Options.
Unfortunately you cannot change the project language after the project has been created.
