mirza
How to enable/disable dialog controls at run time
I am building an installer package that needs to create Windows service either user system log in account or username/password given by user (as in attached image).
1. I need to disable username/password text input controls as per radio button selection (disable them on 'Use System Account' and enable them on 'Enter Credentials'). Should be fairly easy thing but as I am beginner so not getting it done.
2. Secondly, I need to pass this user input (if given) to the service to be created
Any idea how to do these two tasks??
Re: How to enable/disable dialog controls at run time
You can enable and disable the Password and User Name fields through their Control Conditions. Also, I've attached a sample project that implements this scenario.
To install a service for a user, please follow the steps from the How to install a service for a custom user? article.
Should there be any difficulties you encounter implementing something, please do not hesitate to contact me and I will gladly assist you.
Sample Project.zip
(3.14 KiB) Downloaded 782 times
mirza
Thanks for prompt response.
All done now :)
You're welcome,
If you have other questions, please let me know.
mirza
For those who need extra information. Following is easiest way to pass username and password while creating service.
Where [USER_NAME] and [USER_PASSWORD] are the text filed properties.
Hi Mirza,
Thank you for sharing this with us. I'm sure it will help other users.
