Kiran
Uninstall - Modify, Repair and Remove dialog
During uninstall of the packaged software, I see the Modify, Repair and Remove dialog. I have only one feature in the selection list. I would expect only Repair and Remove option (i.e., exclude Modify) in the dialog. Please refer the attached screenshot. Kindly suggest how to have only Repair and Remove in the dialog.
Note: I use professional edition
Best Regards,
Kiran
Kiran
Re: Uninstall - Modify, Repair and Remove dialog
Don't bother on this issue, Got the solution, by setting "Disable Modify" in Add or Remove Programs available under Product Details.
Best Regards,
Kiran
Hi Kiran,
I'm glad you got this working by yourself.
