digocesar
Hide progress bar after build
After finish a project build, should be great if the progress bar on top was hided after finish build process.
I'm used to stay looking to the progress bar to know when it is finished and not look at the message text in the progress output. But if progress bar is not hided I don't know if progress is 99,9% or 100% complete!
And it is simple to be done!
Re: Hide progress bar after build
Please note that you can enable the close this dialog when the build completes option, as you can see below:
If the build is successfully, then the build window will be closed. If there were errors during build operation, then the build window will not be closed.
To open the directory where the installation package was build you can use the Ctrl+G keyboard shortcut.
Please let me know if you have other questions.
digocesar
I don't believe that you will not accept my suggestion and give to me a work around. I don't want to close the build window! Is too difficult to write "progress.Enabled = false" when finish the build? Or is this a dumb requirement?
I think there was a miscommunication and I apologize for this.
To give you a straight answer to you last question: No. Your requirement is a pertinent one and we have already added it in our improvements list. Thank you for your suggestion.
If there is anything we can assist you with just let us know.
Return to “Feature Requests”
