Jaradat
A row with this key was already registered in the table
i have many apps build using Advanced Installer 10.6 , and every thing is ok
i formate may PC, then install the 10.6 Advanced installer, when i want to open some projects this error appeared and i cannot load the projects ??!!!
error 1.png (8.46 KiB) Viewed 2855 times
error 2.png (8.85 KiB) Viewed 2855 times
some projects work others didn't. and when i create new projects no errors appeared.
Please i need to open this project ASAP, i have to publish a new setup today !!!!
the Aip file also attached
Regards
shamel Lite Setup.aip
(227.76 KiB) Downloaded 498 times
Re: A row with this key was already registered in the table
We apologize for our delayed reply but we are a bit busy these days. Your attached setup project has the following repository dependencies which we also need them in order to be able to open it:
1. <AI_REPOSITORY>\Prerequisites\Hasp UserSetupe\Hasp UserSetupe.aip
2. <AI_REPOSITORY>\Prerequisites\Microsoft .NET Frame_2\Microsoft .NET Frame_2.aip
3. <AI_REPOSITORY>\Prerequisites\Microsoft .NET Frame_3\Microsoft .NET Frame_3.aip
Please also send us the above AIPs so we can try to open and investigate your project.
