mmrd
Accessing Path Variables from BAT script
Hello.
I'm trying to access the User and System PATH environment variables during installation.
As a rough test, I have AI calling a .BAT with the command SET > paths.txt. If I run this .BAT manually, I see both the system and user environment variables.
If i call the same .BAT from Advanced Installer, I seem to only get the System environment variables. How can I get both? In other words, how can I mimic what happens when I run manually.
Any help is appreciated.
Re: Accessing Path Variables from BAT script
First of all I apologize for my delayed reply. We were out of the office in the past days.
I'm afraid I don't fully understand what you mean. Can you please give us more details about this (maybe exemplify a bit)?
Have you launched your BAT file using a "Launch file" custom action?
mmrd
Hello David.
Yes. We are launching our BAT file through the Custom File action.
As an example:
When you look at your windows environment variables (System Properties -> Environment Variables) there two sets of variables "User" and "System" (See environment.png attached).
If I run the batch command through the commandline:
SET > paths.txt
it prints a file called Paths.txt. Looking at that file I see both the system and user environment variables are being printed.
If put that same command in a .bat file and run from Advanced Installer (using Launch File), I only get the System environment variables.
How can I get both? In other words, how can I get the same output for what happens when I run
set
manually through the command line.
I'm not sure why this happens. I tested the scenario, but I cannot replicate the issue. Please find attached a sample which implements your scenario and let us know if this helped.
sample.zip
(2.81 KiB) Downloaded 203 times
