korr
XML Element Search
Maybe I'm not understanding this correctly, but Im thinking there is a bug in the xml search for elements. Say I have the following XML :
<connection>
	<server>address</server>
	<speed>0</speed>
	<username>User1</username>
	<username>User2</username>
	<keepAlive>No</keepAlive>
</connection>
To do a search and retrieve the text for <keepAlive> I have to use "Element has index in parent" and the value in that search has to be "4" because its the 5th element, as well as be encapsulated by looking for "keepAlive". Shouldn't it work that the value needs to be "0" as it the first instance of "keepAlive" that I want? If I add another <username> element I then need to increase the value for the "keepAlive" search to obtain ANY result.
Re: XML Element Search
Maybe you can find a way to create the .xml file. e.g. having the following structure:
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<connection>
   <keepAlive value="attributeValue">No</keepAlive>
</connection>
Having the .xml with this structure, you will be able to get the element text, as you can see below:
Edit XML Locator.png (17.36 KiB) Viewed 2985 times
Please let me know if this approach is suitable for you.
korr
We are using an xml that gets exported from a third party program, so while we could manually change the xml it wouldnt work to automate builds.
