Peter
AppSearch before PrepareDlg
Hi Forum,
is there a chance to do the AppSearch before the PrepareDlg or antother Dlg?
I have the idea to search for some installed Products "identiffied by Upgrade Code". In my first Dialog (the "SetupConfigDlg" before the PrepareDlg) I will show with some Checkboxes which Product is installed. Therefore I will need the result of my Searches.
I tried to move "SetupConfigDlg" after my "AppSearch" action, but that doesn't work. (I Know that I have to run the Setup with Enhanced UI by runnig the *.exe.
Configuration of my Dialogs and Action sort.
How can I run the AppSearch before my "SetupConfigDlg" is shown?
Thanks for your help.
Peter
Re: AppSearch before PrepareDlg
Hi Peter,
In order to set the searches to be performed before the "PrepareDlg" dialog or any other dialog, you can go in the "Table Editor" page, "InstallUISequence" table and change the "Sequence" value of the "AppSearch" row to a lower value than the value that dialog has (i.e. 74).
Let me know if this helped, otherwise give me more details about your scenario.
Peter
Hi Eusebiu,
thanks for the Hint to look in the Table Editor Which I had not been used to make adjustments.
The "AppSearch" entry had a lower value than my Dialog, but the "AI_AppSearchEx" Action not. Since I've changed the Sequence value from "AI_AppSearchEx", it works fine.
Peter
You're welcome Peter. I'm glad you got this working.
