deval
Optional automatic updates
I've got the automatic updater working pretty well but now the powers that be are requesting the ability to disable the automatic updater during the install process. So I followed the instructions here http://www.advancedinstaller.com/user-g ... ature.html
I now have a parameter AUTOUPDATE that is set to ON or OFF from a UI component. Easy enough.
To finish things I went and found the updater component under organization and set a condition on it. After building this I get an error that pops up during the install.
Clearly I'm missing something here but I can't see it. Attached is the MSI installer log as well.
The piece that seems to be where it goes sour is here:
Action start 9:03:15: AI_XmlUninstall.
MSI (s) (64:B4) [09:03:15:889]: Invoking remote custom action. DLL: C:\Windows\Installer\MSI5F5F.tmp, Entrypoint: OnXmlUninstall
MSI (s) (64!30) [09:03:49:030]: PROPERTY CHANGE: Adding AI_XmlRemove property. Its value is 'ProductNameImagine LearningProductCode{DF157B06-0567-4AB5-9556-5D51CA11ABDF}REMOVEFeatureAI_TEST_XML_FILE_DIRECTORYAI_TEST_XML_FILE_NAMEAI_CA_MODULE_IDmconfigmconfig1030defaultmconfigdefault13014<configuration>
</configuration>oidEntry_1oidMapoidEntry1114map_3pubTokenMappingmap1714member_700membersmember170114nameassemblyname1014UnityEnginesection_50sectionGroup_2section11014httpRuntimesystem.webhttpRuntime11114oidEntryoidMapoidEntry1014member_4433membersmember1443414param_860member_1287param1114oidEntry_2oidMap_1oidEntry1014forms_1authentication_1forms1014member_4432membersmember1443314param_861member_1287param1214oidEntry_3oidMap_1oidEntry1114map_1pubTokenMappingmap1314httpRuntime_1system.web_3httpRuntime11214mappubTokenMappingmap1114add_126assemblies_1add1814assemblymembersassembly1014map_2pubTokenMappingmap1514member_9
MSI (s) (64!30) [09:03:49:030]: Doing action: AI_XmlRemove
Action 9:03:49: AI_XmlRemove. Executing XML file configurations
Action start 9:03:49: AI_XmlRemove.
AI_XmlRemove: Configuring XML file: "Executing XML file configurations"
Action ended 9:03:49: AI_XmlRemove. Return value 1.
MSI (s) (64!30) [09:03:49:046]: PROPERTY CHANGE: Deleting AI_XmlRemove property. Its current value is 'ProductNameImagine LearningProductCode{DF157B06-0567-4AB5-9556-5D51CA11ABDF}REMOVEFeatureAI_TEST_XML_FILE_DIRECTORYAI_TEST_XML_FILE_NAMEAI_CA_MODULE_IDmconfigmconfig1030defaultmconfigdefault13014<configuration>
Action ended 9:03:49: AI_XmlUninstall. Return value 1.
Any help or pointers would be greatly appreciated. Maybe I'm going about this all wrong.
adv_log.txt
(173.05 KiB) Downloaded 258 times
Re: Optional automatic updates
I think this happens because you forgot to condition the installation of the scheduled task you configured for the updater. Just go to "Updater" page -> "Updater Execution" section and click on Configure Task hyperlink. Then in the "Install Condition" field add a condition like this:
$ILUpdater.exe = 3
where ILUpdater.exe is the component of your updater file.
Let us know if this helped, otherwise please send us the .AIP (project file) and a full verbose log of the installation to support at advancedinstaller dot com so we can investigate them.
deval
Yep that was it. Not sure how I missed that field, thanks!
You're always welcome.
