MLiss@Cetrus.com
Create Database if it does not exist
I am working on an installer, where I want to
Detect if SQL Server Express is installed - ( I have this working )
Check if the user has connection rights - ( see screen shot PredefinedCondition.png )
Create a database if it does not exist - ( fails -- see screen shot TestDialog_Before.png and TestDialog_After.png )
Any suggestions?
Mike
MLiss@Cetrus.com
Re: Create Database if it does not exist
Here is a snapshot of my management console
MLiss@Cetrus.com
What is interesting to note... is that if I create the database in my management console
( see createdDB.png )
The test from AdvancedInstaller works ( see TestWorksAfterManuallyCreatingInSQLServer.png )
Hello Mike,
I think this may happen if you also uses the "Database" ODBC parameter when testing the ODBC connection. If you added the "Database" parameter into the "SqlConnectionString" property, when using the "Set installer property value" event on your test SQL connection dialog, then please remove this parameter from the "SqlConnectionString" property and test again.
Let us know if this helped, otherwise please please send us the .aip (project file) to support at advancedinstaller dot com so we can investigate their settings.
MLiss@Cetrus.com
Daniel,
Here is my aip file... please see if you can help me out.
(I removed the SQLExpress from the zip file... it was 170mb )
Setup.zip
(8.21 KiB) Downloaded 639 times
Hello Mike,
Please note that when you don't have any SQL Scripts or SQL Queries added under your SQL Connection you added in "SQL Databases" page, in this case the SQL Connection will not be established during installation; it will be skipped. Therefore the "Create database if it does not exist" option won't apply unless at least one SQL Script or SQL Query is executed during installation.
So, to achieve what you need please add at least a script under your Sql Connection. For instance you can add a script with a simple query. Something like:
USE database_name;
Let us know if this helped.
MLiss@Cetrus.com
Daniel,
I found somebody else's page that had something similar to what I was trying to do and followed their steps, which included using scripts like you suggest.
It still does not work
I have attached my aip file again. ( I have deleted the prerequisites folder again )
Please help me fix this..
Mike
Bin.zip
AIP for TestDBInstaller
(7.4 KiB) Downloaded 511 times
Hello Mike,
Can you tell us what exactly doesn't work? Which database is not created? Do you get any error during the installation?
Please also send us a verbose log of the installation so we can investigate it too.
MLiss@Cetrus.com
Daniel,
This is getting very frustrating... :(
I have sent you my entire aip file. Did you open it? Did you build it? Did you run it? Does it work for you?
I assume that the information you requested is within the aip project and I also assume (sine your company wrote the software) you can debug the installation process on your end and get all the log files you need. ( I assume that was the purpose of sending you the aip file? )
Please provide more "support" than firing questions back to me, when I have provided you the aip project that exhibits the problem.
Mike
Hello Mike,
I apologize for not giving you enough information. I had already tested your installation behavior on our side and the "TestInstallerDB" database and the "Computers" table are successfully created during installation. Here is attached a screenshot.
Now, to try checking what goes wrong on your side I will further need a verbose log of the failing installation from your side. Also, please give us more details about the issue you are facing with. Can you confirm that it is the "TestInstallerDB" database which is not installed by your setup?
MLiss@Cetrus.com
Daniel,
Communication is key is just about every facet of life...
Thank you for confirming your results.
I have had issues with the machine I was using to test the install and just reformatted it.
I will try again with my installer today and let you know the results.
Mike
MLiss@Cetrus.com
Daniel,
I just tried the TestDBInstaller on my 100% new and CLEAN system
See attached image
How do I setup the installer to generate logs? ( please be very specific as I do not know your product well enough for abstract instructions )
Mike
MLiss@Cetrus.com
Daniel,
something was amiss on my machine... after I reformatted it ... the install worked.
go figure.
Thank you for your help.
Mike
You're always welcome Mike.
