codesynergy
Bug with Folder Shares
I think I've stumbled upon a bug regarding the creation of shared folders. The process of sharing a folder does not seem to respect feature conditions (and possibly component conditions).
Consider the following folder structure:
I have a folder named "share" that the installer creates as a shared folder. You can see there are two of these folders. They are included in separate features:
The features are conditionally installed. So, I would expect the shares to only be created if the feature they are under is enabled for install. However, this does not seem to be the case:
It seems the installer tries to share the folder twice. I am able to workaround the issue by making the share itself conditional (right click folder > properties > Sharing tab > condition).
It's kind of hard to explain, so I've uploaded an example project that reproduces the issue (http://www.filedropper.com/foldersharetest). Basically, the process of sharing a folder does not seem to respect feature conditions, even thought the creation of the folder does. Not sure if component conditions are respected - did not test that.
edit: On a related note, is there a way to access the folder share path (ex: \\MyServer\Share) during installation? Using the folder property gives the non-share path (C:\Web\Share).
Thanks.
Re: Bug with Folder Shares
Please note this is the normal behavior. Our folder share support evaluates only the condition you specify in its "Condition" field. Therefore you should condition each folder share to be set only when its associated component is installed during installation. For instance you can use a condition like this:
$share_1 = 3
Please take a look on our "Edit Condition" article for your reference.
