mumbles76
Powershell Custom actions that write to Install Log
Hello All,
Is there a way within a powershell custom action to write to the install log?
I hadn't thought about writing directly to the install log until recently when trying to debug a particular scenario.
TIA.
Re: Powershell Custom actions that write to Install Log
I'm afraid currently we don't have support for this request. We added your request on our TODO list and hopefully such an improvement will be available in a future version of Advanced Installer. Thank you for your suggestion.
Until then, as a workaround, you can do that by calling a VBS log script within your PowerShell script.
Let us know if this helped.
mmichal
I second this, having this feature would be nice.
I noted down your request too and hopefully this improvement will get a higher priority. We'll update this thread as soon as the improvement will be available.
Our development team investigated this scenario and it seems you can write to the MSI installation log by simply using the "Write-Output" cmdlet into your PowerShell custom action code.
Hope this is still valuable help for you. Also, if you have any questions or doubts just let us know.
Nerdiculous
I tried the cmdlet "Write-Output" and it did not write to the log file.
Can Advanced Installer please give an example of how this works for the development team as stated in the previous post?
I have tested this just now and everything seemed to be working as expected.
The only thing that you need to do is to add the "Write-Output" cmdlet to your PowerShell custom action, e.g.:
After doing so, you should launch the MSI with a command line as it follows:
msiexec /i <path_to_msi> /L*V <path_to_log>
e.g.:
In the log file, you should be able to find the output of the cmdlet, e.g.:
