tdktdk
Vista Registration of VB COM DLL error code
I have a simple COM dll built using VB6. The MSI installer is very simple it just copies the DLL in place with some extra files and then using the self register native library option it registers the file.
All goes well and it works perfectly on XP and other operating systems but on vista I get an error in the form of a message box saying:
Module C:\program files\Product\Product.dll failed to register. HRESULT -2147483645 Contact your support personel.
I have a similar exe installer build with NSIS installer and it works fine on vista.
If I try to regsiter the dll by hand using regsvr32 product.dll on vista I also get an error. Vista says regsvr has stopped working and it is checking the net for a solution that it never finds.
I tried various custom actions but they didn't work - seems they just didn't register the dll.
I'm happy to send the dll and aip file if it helps.
Please help me
ciprian
Yes please send the AIP and DLL to support at advancedinstaller dot com.
Ciprian
Ciprian Burca
Advanced Installer Team
tdktdk
I've sent files.
I've sent files to support as requested my email is tim at thinking machine dot co dot uk please ublock any spam filters.
