Rehal
Update file error
I can not understand how to use update program. it says error when i use update.Or after update it says another program is installed.... Sometimes it says Some of the updates failed to install properly. Please Reply me
Re: Update file error
In order to better understand how to use our application you can walk through the "Advanced Installer Tutorials" which will guide you step by step in creating basic projects.
The "another program is installed" problem may appear if the Product Code of the two versions of your product is identical or if their version number is the same. You can read more about this problem in the "Why do I receive the "Another version of this product is already installed" message" FAQ.
On the same page you can also read why the "Some of the updates failed to install properly" message is displayed.
Rehal
I did all the thing.But If I want to update , then First it install the update and then shows that some of the updates failed to install properly.Please Reply.
ad installer.PNG (20.99 KiB) Viewed 2328 times
This problem appears if the conditions set in the "Installed Detection" tab of your "Updates Configuration" project are not set correctly. For more details you can read the "Why do I receive the "Some of the updates failed to install properly" message" FAQ.
