sfaust
MSI looks terrible...
I am pretty new with Advanced Installer. I'm trying to get my install using the surface white theme with some customizations and overall it's working pretty well. However I would like to build both EXE and MSI projects for this installer. When I set it to 'single EXE' on the builds page it looks great (see EXE test attachment); however as soon as I switch it to 'Single MSI' it looks terrible and really unusable (see MSI attachment). Is there something I'm doing wrong or is this theme not compatible with msi or what?
This is what it looks like in MSI mode
MSI Test.jpg (115.94 KiB) Viewed 3877 times
This is what it looks like in EXE mode
EXE Test.jpg (122.43 KiB) Viewed 3877 times
Re: MSI looks terrible...
Please keep in mind that this is the normal behavior in a MSI package. For more details you can read the Why are my dialogs and controls not displayed correctly FAQ.
sfaust
argh, ok. So what about silent install? Should I just build an msi that is not intended to run dialogs for silent install with switches only?
For a silent install you can use the EXE package with the following command line: MyPackage.exe /exenoui /qn
If you want to install the MSI package, you can extract it from the EXE package using the "/extract" command line (i.e. MyPackage.exe /extract).
