schwarzsurfer
Suite Installation -> Application Installation GUI loses focus
I created a suit installation according to your guide: http://www.advancedinstaller.com/user-g ... tions.html
Everything works fine, except one thing: I want to install multiple applications with the suite installation (4 or 5). I run the application installers with /qr parameter, so the user will see the progress bars of each application when the installation is running. The reduced GUI of the first application installer comes to the front when installed and I can see the progress bar. When it is finished the second application installer is started, but loses focus and the GUI with the progress bar is in the background of the main installation GUI. This status remains until all packages are installed. I have to click on each installation package icon in the taskbar to bring it to the front... I didn't find a way to fix this behaviour. Is this a bug or how can I bring each installation packge installed by the main installer to the foreground?
By the way ... If I use the feature based prerequisite installation method for regular prerequisites like .net or c++ runtimes it shows the same behaviour...
Thanks for your reply!
Marian
Ich weiß, dass ich nichts weiß!
Re: Suite Installation -> Application Installation GUI loses focus
Hi Marian,
Indeed, this seems to be an Advanced Installer issue. A fix will be available in a future version of Advanced Installer, thank you for bringing it to our attention.
schwarzsurfer
No Problem. :)
schwarzsurfer
I have another problem with the suite installation. When trying to change some additional files from the feature-based prerequisites dialog I can't remove or add new files. If I remove the files and switch to another prerequisite and switch back there is the same file added multiple times. I'm not able to remove the files completely and add new ones...
Marian
schwarzsurfer
And the last screenshot...
Can you please tell us if the behaviour still persist when using the latest version of Advanced Installer?
schwarzsurfer
Yes, I use 12.7.2.
This was fixed in version 12.8 of Advanced Installer released on March 23rd, 2016.
Note that the fix is only available for setup packages that have the Enhanced User Interface enabled.
schwarzsurfer
Thank you, works fine now. But why only with enhanced interface enabled?
Marian
Hi Marian,
On Enhanced User Interface, the dialogs are displayed by our bootstrapper and there we can enforce how to display them. When the Ehanced User Interface is not used, we do not have control on how those dialogs are displayed.
